when i boot my rb2011, the screen on it show
routerboot configuration → load kernel from nand → loading kernel
then the secreen stay on “loading kernel”
both winbox, netinstall can’t detect my router and i have tried screwdriver reset, but nothing different.
If you have possibility you might read serial terminal and check if board gives some error message. Have you tried proper netinstall, or you just started netinstall app and checked if router is detected?
mikrotik uses standard cisco style port, so if your cable is compatible your good to go. Personally I used serial pins available on PCB (you have to open case) - these use standard microcontroller levels much like lot of cheap routers.
success to access bios
When booting device from Ethernet, it show “falling back to small packet size” and keep loading, so i can’t find the router option on the netinstall, what is the problem?
