Loading Kernel
Hi
I’ve a big problem: after a power failure I can’t get my rb2011uias-rm working anymore.
It only shows “loading kernel” on the screen.
With serial port it says “system halted”.
I tried with netinstall but after pressing install in the software, Routerboard seems to do nothing.
I’ve to manual reboot and I get same error.
Thank you so much
I have similar problem with my RB2011UiAS-2HnD-IN.
I’m tried to update on RouterOS v6.36 and it’s download it from server but not install correctly, it’s restart and never finish with that. Now it shows “loading kernel”, “starting kernel” and restart. What can i do?? Help me pleasee.
Thank you
P.S. Sorry for my bad grammar
I solved using windows xp instead of windows 8.1.
Solved using Netinstall on windows xp.
Im sorry for this n00b question but Im just starting.
My question is as follows:
Can I apt-get the newest kernel-sources and simply reboot to work with the new kernel?
TNX in advandce
No way.
There is only an image prepared by Mikrotik which could be installed into routers.
There is no tools like apt-get, rpm, dnf etc.
