I have a shiny new 2011UAS-2HnD-IN that just replaced an older model. I have the new one working substantially as the old one did - with three WAN ports bound to a WAN-bridge. Only one WAN port will bind at a time. I have looked at a lot of the material out there and the question I have is this: Can I use PCC for load-sharing if the WAN connections have to use DHCP? In most of the documentation, it appears that the the WAN ports are on static IPs… Is this a requirement for it to work?
Thanks!
