hi guys, i need some advice from any of you, plz…
i got a little problem that make me had a headache
said so, my MT had two ethernet, 1 go to internet and 1 for LAN.
My LAN Network : 192.168.50.0/24
one of users had an ip : 192.168.50.5 = client ABC
i can limit the IP and MAC with ARP static, but that is not the problem.
problem is, user use that IP to switch for 4 client, assume, 192.168.50.6 - 192.168.50.9
where is IP 192.168.50.6-192.168.50.8 is my another client IP (client 123) and 192.168.50.9 is blocked from MT.
so, there are much IP conflict (from 50.6-50.
the solution now that i can imagine is, use a router (not switch)
so, if still using switch there any solution in MT ???
Thanks in future
xaviero,
probably HotSpot server would help you. HotSpot will increase security in your network, user will forced to type login password before communications with outer networks.
However, when user change MAC-address too, than better solution would be management switch, where you can bind port to particular MAC-address.
i don’t use any hotspot, i use wifi connection.
so there are no solution using MT , is it??
You can setup HotSpot to wireless interface.
Information about HotSpot,
http://www.mikrotik.com/docs/ros/2.9/ip/hotspot
where described HotSpot main features and configuration options.
is there hotspot coverage area can reach bout 5km ??? i doubt bout it…
HotSpot is not responsible for wireless area coverage.
Wireless AP-Client infrastructure (Antenna, card, area, etc.) is responsible for that.
