Hello ..
everything works fine and i can surf internet on all clients (pcs) but the problem is that a client can access other clients for a few moments then it cannot reach it, all clients have the LAN interface ip as gateway , i have hotspot on , everything seems to be configured properly , but i don’t know what is that problem , i also noticed that a one client can access another client per time.. i mean.. two clients cannot access the same client at the same time..
can you help me please?
try disabling ‘Universal Client’ feature of Hotspot. for this, set ‘Address Pool’ of Hotspot to ‘none’
thanks for your response .. i will try that and let you know what happens..
the same problem
i noticed that when i ping hots from a local machine get randon respsonse.. many lost packets, sometimes high ping reply
i’m trying to know what happens now for a week ![]()
and if you disable the Hotspot - all is okay againg? please provide your Hotspot config
