Local forwarding vs. CAPsMAN forwarding
Hello all, i would ask to you what kind of difference there is between choosing “local forwarding” or “CAPsMAN forwarding” in datapath settings. I mean, when choose one instead another? Number of expected clients? CPU/RAM of CAPsMAN controller? Or CPU/RAM of CAP? Network topology? i’ve read the wiki, but i did not find nothing useful to clear my doubts. What are the pros and cons which are in the two configurations? Can you please explain me some useful example please?
PS. for admins/mods, feel free to move this topic in the most appropriate section, thanks
Hi.
It is really simple. There are two planes in wifi: data plane and control plane.
By default local forwarding is disable: it means control (capsman) and data ( data from user to internet) are going to capsman manager
If you enable local forwarding: your control will be manage in capsman router and the traffic user data will be forward locally in wireless interface, so you can choose a different gateway to route your traffic and it don’t have to be capsman manager.
is that clear?
did u mean… “By default capsman forwarding is enable” ???
I have edited my post because it was mistake. am i right now?
yes it is correct
Yes @gustavomam, that was pretty clear. So, in basic words, i could have more than one WAN connection (AKA more than one internet provider), more than a gateway, more than a router, many many CAPs, but only one CAPsMAN. Am I right? Have you some practical example to show me? Not necessarily real, but a typical one.
You can have more CAPSMANs operating different sets of AP/CAPs but each CAPSMAN needs to be instaled on separated router.
the CAPsMAN forwarding even works for remote access point connected through VPN, so basically you can deploy remote access point using whatever means of connection to your network. off course, performance is based on the performance of the VPN. i’m using this for deploying wifi hotspot among multiple location with single captive portal on the core network.
one of the unexpected result that we like is: when the wan connection loss/disconnected, the wifi is gone too. this actually solve our issue to detect internet connection so user won’t have blank connection (connected to wifi but no internet) anymore. no internet, no wifi :smiley:
