I am having problems accessing my website using their URLs (http://www.mysite.com) from the internal LAN. Is it possible to setup a local loopback to fix the problem?
Tim
Tim
I don’t really see how a reachability problem would be fixed with a loopback, but you can create a pseudo-loopback with an empty bridge (that acts for all intents and purposes as a real loopback, aside from some extra resource consumption).
–Eric
What is the best option to solve the problem then?
why do you think that the router is at fault? reachability problems can be caused by anything, bad cable or server problem. a loopback doesn’t have anything to do with browsing and reachability, maybe you mean something else?
i think he’s trying for a nat-on-a-stick config - this is what cisco calls it. Basically he wants to use the public ip on the inside, go out and back in again - which just takes a few nat rules to make it work.
Yes, that is what I am trying to do. How can it be done with Mikrotik?
Tim
If you’re on the same interface as the server (LAN?) then you need to dst-nat to that machine from the LAN interface …
Sam
Ok, can you give me an example?
add chain=dstnat in-interface=0-inside dst-address=ex.ter.nal.ip protocol=tcp
dst-port=80 action=dst-nat to-addresses=in.ter.nal.ip to-ports=0-65535
comment=“” disabled=no
I am not using this setup, but something similiar to the above should work. You are basically saying when a packet goes to the public IP:80 and its coming from internal, then dst-nat it to the internal ip.
Sam
maybe i am misssing something, but i think the static DNS cache entry will help, just assosiate your local website name to the local IP of the site
That works well if your using MT dns cache from internally.
Sam
Yeah we are using Windows Server for our dns so that is not possible. I tried the fix above but it didn’t work.
Tim
I am still stuck with this one, the above didn’t work.
Tim
I have the exact same issue. I can reach my web server from an external source (home computer), but am not able to reach the same web server from within the network after replacing my Netgear VPN router with a freshly installed MikroTik firewall/router. I have a dstnat setup almost exactly as published above and can route traffic to any IP including the MikroTik router at 192.168.168.1, but I can’t seem to reach any other IP’s/machines on the network from within the network on port 80. I’m stumped!
I found the solution through a few posts/links, thank goodness.
This worked for me:
Found in this thread: http://forum.mikrotik.com//viewtopic.php?t=5509&highlight=
hih
