local network routing not working
Hi
I’ve been trying to resolve this issue for some times. And I have had no luck resolving this issue.
I have a MikroTik hAP ac.
The 5 ports are linked to the same bridge.
There is 3 WIFI AP’s setup (1 being virtual)
All ports have internet access.
Single DHCP is working across all ports and WIFI
The problem is. I can’t ping or connect to systems connected on the network ports from another network port. But are able to ping from the WIFI.
Hey Raiders13,
Check this out if it works for you then.
1.Check Your Settings. First, check your Wi-Fi settings.
2.Check Your Access Points. Check your WAN (wide area network) and LAN (local area network) connections.
3.Go Around Obstacles.
4.Restart the Router.
5.Check the Wi-Fi Name and Password.
6.Check DHCP Settings.
7.Update Windows.
8.Open Windows Network Diagnostics.
Regards,
Mika Hawkins
