Has anyone else come across local variables not defining on the RB912R?? Only some were not working on 6.44.6, after upgrading to 6.49.7 it seems no :local variables are working
Any ideas?
Any ideas?
I use local variables everywhere and all works, for sure is your fault.
Code example?
Figured it out over the weekend, was 100% my fault
Thank you for sharing the reason, very kind to all the other users of the forum.
Good point…
Was trying to run a script with verbose=yes to see where it was failing, didn’t realise you cant assign local variables in a verbose terminal.
