Is there any to know for sure which configuration reset file does a mikrotik have ? By TR-069, I send configuration reset file using the download configuration with “X MIKROTIK Factory Configuration File” filetype. However, some of my devices have this file, others don’t have. So, I’d like to check if the file exists and what is its content.
Hence my questions :
- Were is located the file ? I don’t see it there
[admin@PROD-SDG2_1230444] /snmp community> /file print
# NAME TYPE SIZE CREATION-TIME
0 flash disk jan/01/1970 01:00:04
1 console-dump.txt .txt file 19.8KiB jun/29/2018 16:05:13
2 flash/pub directory jun/15/2018 12:58:31
3 flash/user-manager directory jan/01/2002 02:00:03
4 flash/user-manager/sqldb file 80.0KiB jun/14/2018 10:25:04
5 flash/6F1307748E4B.rsc script 23.0KiB jan/01/2002 02:01:09
6 flash/6F1307748E4B.txt .txt file 79 jan/01/2002 02:01:03
7 flash/log.1.txt .txt file 160.1KiB jun/29/2018 16:42:34
8 flash/skins directory jan/01/1970 01:00:05
9 flash/user-manager/logsqldb file 6.0KiB jun/14/2018 10:24:52
10 flash/backup.backup backup 52.6KiB jun/29/2018 15:54:16
11 flash/log.0.txt .txt file 76.8KiB jun/29/2018 16:49:47
- If I can’t find the file, is there any command which could give me its name and creation date or content ?
- If such a feature does not exist, is there a plan in near future to implement it ?
- Is there a plan to make it possible to download this file without netinstall or tr-069 ?
Thank you very much,
Regards,
Grégoire
