Hello
is there anyway to lock ap mac address (something like ubnt devices). because i have 2 ap with same name and different mac address . mikrotik only connect to one of them and when i select another ap mikrotik again select first ap.
ap using same sssid and i only can connect to one of them! anyway to connect ap and lock it with mac address?
Check access list.
For a client MikroTik in station mode use connect list to specify the required AP.
Switch off default authenticate on the wireless interface to only connect to APs in the list.
Hope that helps
Nick
thanks alot dear, with connect list and unchecking default authenticate it is ok. ![]()
Hello, good afternoon could I please be more specific and steps to follow to fix AP MAC in antenna mikrotik SXT lite 5, try what I understood before and I did not find it.
