Lock to AP MAC function
I was wondering if it’s possible to lock CPE/Clients to a specific AP’s MAC address?
I mean, for example, 4 AP’s and I want my client to connect only for one, avoiding connections with the other ones.
If it is a mikrotik client, then add a connect list entry (connect and then copy it from wireless registrations)
and then turn off Default authentication
If you want to control it on the APs, then use an access list entry
Hope that helps
Nick.
How can I add connect list?
Sent from my iPhone using Tapatalk - now Free
Is it necessary turning off Default authentication?
anyone?
