Lock VPN user to static IP
What would be the best option to make sure that VPN user is using statically assigned IP address to his VPN secret. In case user edit VPN client and puts other IP the Mikrotik would disable VPN or would not allow to connect.
I think user-man with an attribute of framed-ip-address=x.x.x.x for that user.
If the number of users is not large and you don’t want to set up any Radius, you could also use remote-address=x.x.x.x.
yep this is what I used to set remote address, and created a firewall rule what that address may access on the network, but the user can go to VPN interface set up on PC and manually change IP address within IPv4 settings and I believe it will work and this way user goes around the firewall rule.
