I recently installed a RouterBoard 600a with 8 Ubiquiti XR2 and Daughter board. It worked fined for awhile but, lately it had locked up. I power cycle, did a hard reset, and can’t communicate with the router through neither LAN ports. Had anybody had the same problem?
from the serial console does the ether port display as registered when pluged into a switch, router or device?
If so then it is possible I am not correct.
I am only giving a possible scenario, you must continue your diagnostics and verify waranty etc.
