I’m seeing a weird issue, and as far as I know all of a sudden (I have a non-routerboard AP so didn’t realize the issue).
Here’s my config, pretty simple:
/caps-man channel
add band=5ghz-a/n/ac name=5ghz-channel reselect-interval=1h save-selected=yes skip-dfs-channels=no
add band=2ghz-b/g/n name=2ghz-channel reselect-interval=1h save-selected=yes skip-dfs-channels=no
/caps-man datapath
add bridge=bridge-local local-forwarding=yes name=default
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=default passphrase=..
/caps-man configuration
add channel=5ghz-channel country=“united states3” datapath=default mode=ap name=5ghz-default security=default ssid=
LightSpeed
add channel=2ghz-channel country=“united states3” datapath=default mode=ap name=2ghz-default security=default ssid=
LightSpeed
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=5ghz-default name-format=identity
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=2ghz-default name-format=identity
On CAP, despite using local-forwarding=yes, I’m still seeing “CAPSsMAN forwarding”:
/interface wireless print
0 X ;;; managed by CAPsMAN
;;; channel: 2447/20-eC/gn(30dBm), SSID: , CAPsMAN forwarding
name=“wlan1” mtu=1500 l2mtu=1600 mac-address=… arp=enabled interface-type=Atheros AR9300
mode=ap-bridge ssid=“LightSpeed” frequency=auto band=2ghz-b/g/n channel-width=20/40mhz-Ce secondary-channel=“”
scan-list=default wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
1 X ;;; managed by CAPsMAN
;;; channel: 5300/20-eeCe/ac(23dBm), SSID: , CAPsMAN forwarding
name=“wlan2” mtu=1500 l2mtu=1600 mac-address=… arp=enabled interface-type=Atheros AR9888
mode=ap-bridge ssid=“LightSpeed” frequency=auto band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee secondary-channel=“”
Any clue what when wrong? Both CAPsMAN and CAP are running 6.41.2
