So. I went and disabled all IP services – ftp, ssh, telnet, winbox and www.
What can I do to regain access to my router, other than resetting it?
You reset it
or try mac telnet maybe
If he’s blocked telnet though, wouldn’t that prevent telnet from working?
I’d be thinking reset is only fix…others may find another solution!
You missed one little detail, “telnet” and “MAC telnet” are two different things, the latter is not “telnet for Apple’s OS”. ![]()
