I know the admin password but when I changed the IP address, it never came back.
I have plugged into the serial port and by hitting enter as it boots I can get to a menu. But what is one to do with that menu. The docs just don’t cover it.
When it attempts to boot, I can see the wireless interfaces from my wireless laptops and it does have the same SSID that it had before so I am assuming that the OS is running yet the serial port gets locked out right after I see
Starting Services…
And that is all I see on the serial port. I have tried the “Reset Configuration” from the serial menu but it doesn’t seem to do much other than reboot it again.
How can I get logged in to this thing via the serial port so I can assign some kind of IP address that will give me access again?
The problem was having a serial cable that didn’t have the handshaking signals connected. It only had tx, rx, and gnd connected. As a result, the first menu was visable and the boot process up to “Starting Services…” And then nothing more could be seen. With the correct cable, I get a login prompt!
But if I had to format NAND, how would one go about it if they couldn’t get to a login prompt?
Try’d mac-telnet? if you only messed up ip configuration, router still should be accessible via mac-telnet (available via winbox, click three dots near “conncet to”)
