I accidentally unchecked ‘Remote’ from the server settings… and once I disconnected I cannot reconnect. I guess that told the server not to accept remote connections any longer. What option do I have besides clearing my config ?
(Agent is on x86 routeros 3.22, dude 3.2)
Here are some possible ideas. Log into the web page and see if you can fix it from there.
Run the dude directly on the device… since it is routeros I suppose that is not possible so maybe… copy the dude folder to a pc and install the dude on it. Run the dude directly from the pc and fix the check box then copy the folder back.
I could not find where the toggle is in a quick look at the files.
HTH
