I was doing some firewall set up and accidentally locked myself out. I will reset and upgrade to OS 6.6 again. However,
I wanted to know whether it’s possible to apply the same firewall rules to two different Ethernet ports if I don’t want to
use the address list. I had an Apple Extreme on Eth2 for my personal network and a Linksys wireless access point for my guess.
I tried to set up firewall rules that would apply to both device but could not find the IP address that the Mikrotik assigned each
device through the Interface panel. I realized that I didn’t want to assign a static address to each device…a dynamic one instead.
So, I decided I want the Mikrotik assigning IP addresses to both device so I can apply the same firewall rules to both device and to
not have more than nine rules. What should I do in the forward chain?
Thanks in advance!
