Locking users to panels/views
sorry if this has been asked before.
Is there a way to lock a user(s) (read-only) to a certain view of panel?
I have managers that want to see certain parts of the network via the dude but I don’t want/need them to view anything else on the dude.
Thanks.
You might have thought of this but you could export just the panel you are interested in as graphic and host it on another web server. Someone did this before…
Hey, thanks.
I haven’t really had a need to play with exporting beyond the odd export for reports.
It is a good idea, might give it a try, sadly it probably won’t be enough as they like to be able to view the link speed/bandwidth etc.
But I’ll give it a try.
Thanks again and shame this feature isn’t supported by the looks of things.
Aik
I know it would be awesome if they would implement a bunch of features people have been asking about. Security per user per map is one of them… Anyhow there is a chart you can add individual graphs to, then you could export the link graphs as well. You should be able to find the posts where someone used a batch job on a schedule to copy the images to a web server with ftp.
GL
Lebowski
