log disabled... How to enable it?
Hello.. I am having problems with the log of a mikrotik RB951
When I open the log, it is white, show nothing, … seems like somebody has disabled it… is it possible?
If so, how can I enable it?
Go to System → Logging and check what the router have there.
I also have a problem with logs on the RB951G router. When I open a log, entries are often not presented chronologically. ROS: 6.42.2.
I have seen this happen if the NTP server is returning funky values or if there are multiple alternate servers that are not synced.
Sent from my iPhone using Tapatalk
