Log downloader question
I have a system where I download logs from MT router and then have a program that parse the log to add internet usage into our accounting system.
All our APs are MT and we recently changed our gateway to a MT router with load balancing.(RB532A ROS 3.10)
Now here’s the question:
Under /IP ACCOUNTING
I’ve enabled accounting with web access, accounting local traffic with threshold of 1024
The log downloader downloads the logs, but it seems like just management traffic, e.g. I’d download 18MB ROS upgrade but the log willl only show not even 1MB.
Should I run log downloader on each AP as they are not NATted, but subnetted? Or how can I setup the main outgoing router to ‘display’ all traffic going through it in the accounting log? (I can also use API to download accounting if needed, instead of LogDownloader_1_1.exe)
Thanks in advance
Ekkas
