LOG Error
Hi All,
I have come across a Very strange problem in Mikrotik as my Backup files and Other Config files in the MT is not able to see.
If i give “File Print” in the command prompt of MT its not listing any files. I had around 200 files in it.
And also my Local log is not showning any logs in it**(" Log Print").** Its very strange for me and i am not able to find a soulution for the same.
CANNNNNNNNN anybody help me in this regard
Your early response in this regard will be highly appriciated.
Sishith
send support-output file to support@mikrotik.com
will it be possible for you to suggest me some solution without sending the support file because to send you that file i have some authorisation issue from my office .
Sishith
sorry, no help unless you can send that file. how can we help if we don’t see your configuration?
Hi sis..
that’s file, i thing containing as your router config… :wink:
and only MT can read and help you.
regards
BalimoreDOTcom
