Hi everyone,
I need to know what is the meaning of the “len” attribute in the firewall log line.
I have firewall log lines like this:
Nov 21 11:47:02 83.139.194.xx firewall,info Mik_MASTER: FW_OUT srcnat: in:(none) out:ether4, proto UDP, 10.8.4.183:15840->82.48.142.1
34:37414, len 84
Nov 21 11:47:12 83.139.194.xx firewall,info Mik_MASTER: FW_OUT srcnat: in:(none) out:ether4, proto UDP, 10.8.4.183:15840->71.64.25.13
4:36699, len 63
Nov 21 11:47:22 83.139.194.xx firewall,info Mik_MASTER: FW_OUT srcnat: in:(none) out:ether4, proto UDP, 10.8.4.183:15840->85.138.196.
169:1145, len 60
Nov 21 11:47:32 83.139.194.xx firewall,info Mik_MASTER: FW_OUT srcnat: in:(none) out:ether4, proto UDP, 10.8.4.183:15840->18.171.5.19
3:4423, len 61
Nov 21 11:47:42 83.139.194.xx firewall,info Mik_MASTER: FW_OUT srcnat: in:(none) out:ether4, proto UDP, 10.8.4.183:15840->87.17.97.23
8:16785, len 131
Nov 21 11:47:52 83.139.194.xx firewall,info Mik_MASTER: FW_OUT srcnat: in:(none) out:ether4, proto UDP, 10.8.4.183:15840->87.19.232.1
56:29457, len 131
What is the meaning of “len” ? is it the size of the packet in kb? is it the length of the header in bytes?
Thank you, i had no luck reading the manuals
