Hello guys!
Is it possible to turn off a log entry for a specific user’s login? Or can disable logging for api?
My monitoring login and out of the device every 10 seconds, important logs are being missed.
I already thought about disabling system topic “account”, but I didn’t do it, because I’ll lose other important logs about attempts to enter the device.
What device and/or service/application is this?
I do not think you can just remove parts of log for one user.
If you have remote scripts that do log in to the router and does stuff, it will be logged.
This is way I removed all remote script and also SNMP, and instead made the router itself sending out all that you need to monitor my rotuers.
Look at the Splunk project in my signature.
