Log into winbox with certificate instead of password
Hi there,
Is it possible to login to winbox with a username + certificate instead of a username + password? From what I can see this is not possible, however it is possible to do this with ssh but then I will have to disable winbox mode.
Do it with SSH and then disable winbox service…
Or as “better than nothing” solution, you can use ssh as tunnel and connect to WinBox through there (I didn’t test it, but I don’t see why it wouldn’t work).
How would the set up look like?
Thx
