Dude is writing *.log files in default subfolder, log files in very simple format, and i cant find, who goes the selected web page or which hotspot user goes to http page which is looking for,
There is a program called SEC… Simple event correlator. You can use regular expressions and determine what you want to know about. That information can be sent to you as an email. You will need a linux box to run SEC. This would require quite a bit to get working from scratch but worth it.
