I know this topic has already been mentioned meany times before, but it seems there was no solution found yet.
I have about 25 RB Metal 5SHPn wireless stations. These stations are located in a magazine hall and they are mounted on trolleys which move slowly along a looped route, slower than walking speed. The stations are running RouterOS v. 6.19 and this won’t be changed, at least not in the close future.
The stations are connected to one SSID on one access point working in 802.11a on a fixed frequency. The access point is made by a different vendor than Mikrotik, but it’s a high end product capable of handling 25 stations per radio. The AP broadcasts 3 SSIDs, data rates allowed are: 6, 12, 24 as basic and 18, 36 and 48 as supported. 54 Mbps is disabled on the access point. Signal levels received by the stations are ok - at least -70 dBm@48Mbps, noise and quality parameters are at least good. For 54 Mbps the signal level was low, it reached the sensitivity level of the station’s radio.
If it matters, the stations work in station-pseudobridge-clone mode.
Trouble is, I keep getting this in the log of the stations:
jan/25 04:19:56 wireless,info FC:xx:81:xxxxxx@wlan1-gateway established connection on 5220000, SSID xxxxxx
jan/25 05:47:35 wireless,info FC:xx:81:xxxxxx@wlan1-gateway: lost connection, no beacons received
jan/25 05:47:40 wireless,info FC:xx:81:xxxxxx@wlan1-gateway established connection on 5220000, SSID xxxxxx
jan/25 06:46:24 wireless,info FC:xx:81:xxxxxx@wlan1-gateway: lost connection, no beacons received
jan/25 06:46:29 wireless,info FC:xx:81:xxxxxx@wlan1-gateway established connection on 5220000, SSID xxxxxx
jan/25 07:27:29 wireless,info FC:xx:81:xxxxxx@wlan1-gateway: lost connection, no beacons received
jan/25 07:27:34 wireless,info FC:xx:81:xxxxxx@wlan1-gateway established connection on 5220000, SSID xxxxxx
Beacons are broadcasted on the lowest basic data rate, for this rate the signal level is more than satisfying. Why is this happening? What more can I check?
Looking forward to your responses,
Jacek
