log ping results
My pings sometimes result in a timeout.
I’d like to record the timestamps of this happening.
Is there an easy way to do this? Thanks in advance!
You could use tool/netwatch to set a test (which is based on ping) to 1.1.1.1, where you can specify an action in the down tab of scripting section to save the timestamp on log.
See more about netwatch https://help.mikrotik.com/docs/display/ROS/Netwatch
