Log PPTP
Hi all,
To be able to connect to my network from the internet, i have managed to setup a pptp server some time ago. following an example.
Today i found the third line in the log. I have seen similar lines but other ip address a few day’s ago.
“Whois ip” say’s me that the ip address is from the US. Since it was not me who connected to the router i’m affraid that my router is not good secured anymore.
Or is this acceptable since there or no other lines in the log refering to this ip address? So the ip did no harm.
15:40:46 interface,info ether8-slave-local link down
15:40:48 interface,info ether8-slave-local link up (speed 10M, full duplex)
16:10:59 pptp,info TCP connection established from 139.162.102.46
17:15:42 interface,info ether10-slave-local link down
For now i disable PPTP awaiting your answers.
Thnx Ward. RB2011UiAS-2HnD-IN
As your 1723 TCP port is open from outside, it is “normal” to see this kind of line. Hackers always try to connect to open ports.
Regards,
