/log/print with queries does not work properly (for me)
I have this:
/log/print
?=topics=firewall,info
?>.id=[LAST LOGGED ID]
with which I would like to monitor routers log for firewall entries where I “remember” the last ID from last entry from each run and when the log entry ID was “*FF” and using this
/log/print
?>.id=*FF
the API doesn’t return new entries although I know there are new entries (with ID *107 for example)
How can I acheive this so when using always the ID from last entry of the run I will get new entries?
Thanks!
.id field values are not comparable.
Is “time” then comparable and how? As I tried also with
?>time=Nov/20/2011 11:11:11
for example and didn’t work either.
AFAIK best chance for you would be to run
/log/print
=follow=
.tag=log
or add query for topics , if you like, so you see only newly added entries in the log. So you get details as entry is created.
Thank you! I’ll try that.
