LOG SSTP access
Hi fellow Mikrotik users,
For PPTP I do this for logging:
14   ;;; PPTP-VPN rules
     chain=input action=accept protocol=tcp dst-port=1723
15   chain=input action=log protocol=gre log-prefix=""
16   chain=input action=accept protocol=gre
When a GRE tunnel is established, I know someone logged has in with success.
However, I get more than a 100 hits on port 443 every day. How can I log whether a SSTP tunnel has been established with success vs just another harmless port scanner driving by?
Regards,
Jeroen
I got a step closer!
You can find users that logged in with success via below line of code, pasted in a terminal. Of course, appropriate logging should be enabled first in order for this to work.
log print detail where buffer=memory  && message~"authenticated"
It will produce this output
time=dec/10 20:35:02 topics=sstp,ppp,info message="<sstp-TESTUSER>: authenticated"
I can now try and write a script to condense the output to, for instance, TESTUSER logged in on dec/10 20:35:02 and feed this BACK into a log topic of choice.
Unless someone knows a better way haha:-)
Move sstp server from port 443 to some other port.
Doesn’t Windows 7/8/8.1 always connect to 443? Must try that asap and I’ll post whether or not it can be changed
