I wants LOG of all the websites by name, which is visited by all the customers.
Please explain in details, Thank you all in advance.
GOING TO USE MT SYSLOG.
you will have to use transparent webproxy on your customers. after you have configure that, you can enable webproxy logs which will contain what you want.
Thanks Normis,
But i am using RB133 at my customer end. Is it possible with that. If yes please explain HOW
Yes, it is possible.
Make sure you are not using caching, as well it is recommended to send logs to remote location.
Transparent proxy configuration is described at the documentation.
Set ‘web-proxy,debug’ or ‘web-proxy,!debug’ (probably the better one, as it generates less lines) at ‘system logging’ for topic.
Use system logging action to configure logs (sent to remote log server).
Thank you Normis
I will be installing today
