I got a issue recently. I used to log in my routerboard through radius authentication. Now I just can do it when I set in the user (using userman) the full profile (Doesn’t work with any others, even read and write). Does anyone know how to fix it?
If I understand your situation the routers will use the local user database first and if not found will then ask your Radius server.
Logging will show the local user in the local log.
Remove the local user. However, if you need access when the Radius server is down, you won’t be able to get in unless you
have an admin user stored.
hi Guys,
I have RB1000 with four interface.
i want to configure the ether1 with my ISP IP address , ether2 as hotspot and ether3 to send out DHCP IP in the range of 192.168.2.1 -254 with internet from ether1.
How can i link ether2 and ether3 with different ip to Ether1?
hi,
i have RB951G-2Hnd and i configure ether1 as wan and ether2 as hotspot. and every thing is very ok.
i want to bridge ether3,4 and ether5 to my ether2 which is the hotspot, to get ip address from the hotspot ,how can i go about it?
