logging in different files - ? [SOLVED]
Hi
example:
I have two rules that need to benefit from logging.
TARGET#1 - occurs approximately twice an hour
TARGET#2 - occurs approximately 5 times a minute
TARGET#1 lost in the log TARGET#2
How do I appoint for each rule its own log file?
TARGET#1 is logged in the file “target1.0.txt”
TARGET#2 is logged in the file “target2.0.txt”
Best regards.
you can (and should) log everything to a remote syslog, and set up filters there.
:frowning:
OK
Thanks.
Very uncomfortable for the way ‘all in one “box”’ :slight_smile:
thanks again!
I set up “remout syslog” on Dude on Windows. not bad :smiley:
Best regards.
