Logging on secondary HDD problem
Hi I am new on this forum :slight_smile:
I have a problem with logging traffic on the MT (v3.x and 4.x). I collect logs on the second IDE HDD and when there is only one file is fine but when the MT creates a second file when you enter the Winbox CPU jumps to 100% and takes up the whole bandwidth for about 30 seconds. When will restart or lack of energy logs do not move CPU goes to 100% and I have to delete the current file directly from MT and restart the server then this works. The disk is old so I will try to have on the CF card. MT is installed on a Compaq Slim PIII 450MHz, 256MB RAM and 128MB CF card. Does someone met with a similar problem? Perhaps this is a bug? Logging only www traffic.
add action=log chain=forward comment="" connection-state=new disabled=no log-prefix=www
add disk-file-count=100 disk-file-name=secondary-master/log disk-lines-per-file=65535 disk-stop-on-full=no name=logi target=disk
Thanks in advance for your help.
