Hello everyone!
I’m new to the forum (but not to mikrotik products) and I’m now configuring the Logging & Syslog as I saw in this guide http://wiki.mikrotik.com/wiki/Securing_New_RouterOs_Router#Port_Knocking
The problem is that when I put in the terminal the line
/system logging action add target=disk disk-lines=300 name=FirewallHits
( I have choosen 300 as max lines to store) the terminal says to me that there is already a disk action with such name file. So it fails.
Going further, when I put the command
/system logging add topics=firewall action=FirewallHits
the terminal says to me that input does not match any value of action.
What should I do?
Also, I did not understand this:
“Under *nix-like OS you should do that (FreeBSD, for example):” etc…
Should I do something similar even if I’m under windows 7?
Thanks ![]()
