Logging to a remote Syslog server?
Using routeros 5.7 on a rb1100 I hate to ask what apears to be a simple question, but ive searched everywhere with no avail! I’m trying to get my mikrotiks to log to a remote syslog server, I see where you setup a logging action, and select “remote” but where do you set the ip of the syslog server???
Thanks in advance!
–John
system logging action edit
or use winbox System/logging/Action doubleclick to remote and set your syslog-server…
Ok (shrug) now I feel silly I didn’t see that. Thanks
–john
Here is a more challenging question -
Is there a way to log to a TCP enabled Syslog server instead of UDP?
For remote logging , This may help.
http://aacable.wordpress.com/2011/11/29/howto-save-mikrotik-logs-to-remote-syslog-server/
I’ve still not been able to get the Mikrotik to log to a TCP server instead of UDP.
Anyone else have any ideas?
UP
I have a system that sends logs for every new connection accepted from a nas to a remote syslog server over wan, and in this case, TCP is the appropriate protocol, because i cannot and i dont want loose any packet.
It’s possible to know how to make it possible, since in ROS i cannot find any command for select TCP instead UDP?
I ended up just going UDP/BSD. So far it’s been just fine, but I’m also not logging to a location outside of my network.
I recently published a guide on setting up remote logging with Syslog and Grafana Promtail and Loki.
