logging trafic
By Danish law i need to log every 500. packets or the start og stop packet of a session…
It is a stupid law, yes… but hey what can i do… i may get a ticket or jail time?
But can this be done by RouterOS? to log every 500. packet to a file?
I use a RB333 atm. but upgrading to RB433 or x86 in time…
what does it mean - ‘every 500.’? every 500th packet?
I think he means “first 500 packets of every session” or something like that. OP - have you looked into the CALEA or into the packet sniffer features? Both of them are meant for capture of streams for similar purposes.
Normis is right, you may to go with Calea,
it has option,
sniff - generates a tzsp stream that can be directed to any Wireshark (Ethereal) server
you may use,
pcap-file-stop-count - maximal packet count
when to stop current tzsp stream.
More information about Calea,
http://wiki.mikrotik.com/wiki/Calea
It’s every 500th packet’s and not per session…
Never hear about CALEA… :slight_smile:
But It looks like the thing i need… Thanks normis and sergejs…
what is the use to log every 500th packet ???
Danish terror law… it’s so stupid…
They can’t track anything…
It says that i need to log:
protocol - dst ip+port - source ip+port - date/time
There is two ways… start/stop packet of a session or every 500th packet…
And only if there is over 100 users on my network…
So what they say is that 1 of a 100 is a terrorist?
Stop, stop!
What exactly do you need to log - “protocol - dst ip+port - source ip+port - date/time” OR “every 500th packet”? If first - it’s just NetFlow information! NetFlow data contains address/ports, protocol and start/stop time of every IP stream - it is what we use when law machinery approaches us about another misdeed
I need to log “protocol + dst ip/port + src ip/port + date/time” on every 500th packet…
(drop 499 packets and log 1 then drop 499 again and log 1)
well, NetFlow give you more information than you need =) so you may rely on it. you will know all packets, not only every 500th
You may use option ‘nth’ and action=log.
Add to nth=1,501 action=log, that should log every 500 packet, it will give you src/dst address and port, time as well.
Chupaka,
I hear what you say about the netflow, but maybe with such a stupid law they makeit worse by saying that if you take a 100% netflow you are infringing on peoples privacy by logging ALL data!
You never know.
Move to africa, we dont have laws… :wink:
you do not log all data, you only log connection information, w/o stream data - all clear =)
On my way :laughing:
