weird stupid issue.
upgrade to 5.7
i get to the gui login page from the public ip, but can’t login in. keeps saying invalid user name pw? but works flawless internally?
weird stupid issue.
upgrade to 5.7
Are you sure you are logging into the correct router?
only have one
Do you have “web” permissions on your account?
where is that setting at? i did not set anything from the defaults
this worked flawless in 4.17, did some setting changed?
this has to be bugged…my public ip is 10.0.1.70 behind another router. internal is 101.0.1.1
i have a computer on the same public ip range 10.0.1.29
the 10.0.1.29 is coming in on the wan eth connection and can browse to usermanager at both 10.0.1.70 and 101.0.1.1, but can only log in on 101.0.1.1
i get a invalid user name and ps, trying on the 10.0.1.70.
another computer on the mikro router itself at 101…208 can access and log into both ip’s fine
on 4.17 this works flawless with 0 issue.
im wondering if this is bugged on the 700 series routerboards. i tested this in a sandbox on a x86 setup and don’t have the issue.
i set the default configuration and still have the issue? anyone at all?
No its not a bug that I know of. Did you say you had a public address in the 10.x.x.x range? That is not a public range, that might be part of your problem.
as far as the 750 is concerned the 10.0.1.70 is a public ip, this router sits behind several other routers
i a simply roll back to 4.17 and the issue completely vanishes. a complete reset doesn’t fix it either.
the issue does not show up in x86 version
how do you open a bug ticket for mikrotik?
