What does this message mean?
system,error,critical login failure for user via local
i guess “local” is serial port, but i have no connections to serial port
i guess someone try to login from LAN ![]()
but why “via local” , not “via ether1”?
you can see everyone will try to attack your machine in system logging when disable=no
be sure, you must make securely of your router from public, local, unwire interface ![]()
“via local” this is “keyboard”… my router is PC x86… someone from coworkers check router’s heartbeat by typing this trash on keyboard ![]()
