Login Modification
Hi
I have created a hotspot using the internal radius server (User manager) and would like to modify the login page.
I would like it to open the status page in a separate window or tab if the login is successful.
Unfortunately I am new to MikroTik and know absolutely nothing about HTML and javascript.
So far I have modified the login.HTML but just the default picture and added our email address and web page as links on the page. The rest of the login.html page is still as it was.
Any ideas are very welcome
Craig
decide your objectives first..!!
what exactly you want to do..?
If you want just to modify the HTML page and edit front page then you need basic knowldge of HTML and if you want to open new tab for status and all then you must run JS. Visual editors will not work with HTML login page beacause it just breaks the code.. so get it done from any html expert.. mikrotik don’t have in built option for this..
