Hi
My name is michel and i am very new here.
I work since a few years with MT equipment.
at this moment i am working on creating a login page for mobile devices and PDA’s
I read some information about you need a java script for reconition of the use of a mobile phone or PDA
- How to create a login page for mobile and pda devices ?
- What do i need for the reconition of the mobile phones / pda?
- Where do i put everything in the MT board
So i need really help with this one
Can anyone help me out with this issue
m.kuster@qwi-engineering.com
please check In RouterOS 5.x the Webfig configuration interface. Your browser will have to support javascript.
I am using now at the moment V4.17 on my mikrotik routers at customer peremisis.
I need help starting up. What i mean is where can i find this javascript and how and what do i have to modify for the redirection.
Also where in the login.html do i have to put this script.
When some one will connect with his mobile he will get redirected to a map that contains the login for mobile phones and PDA.
I heard that iphone is difficult
please help
you will have to install at least RouterOS 5.0 for this feature to be available. Better of with 5.4 or as my tests show 5.5 when released. Then you just open router IP address in your browser and go to open up webfig.
webfig works great on my android phone (HTC Evo) and android tablets (Acer Iconia A500 and Motorola Xoom)
Router OS Ver 5.4
Ok thanks
I will put Version 5 on the boards.
Can you provide me with more information?
Is there any change to post the script you are using and where in the login.html i have to put some tags
