Hi, I have a nice working (mikrotik) hotspot with over 50 user’s.
the only problem is that some websites, where you have to login with name and passwort seem to reject the login. No comment at all, just the login screen appears again. If i bypass the hotspot everything is OK. Somebody any idea??
JanWSchut
then I think password isn’t ok ![]()
It could be!
Nop, it hasn´t anything to do with the hotspot passwort. because the user is already logged in. I am talking about the login at a external website.
Aps ok!
then.. it could be that you are using load balancing. If you use load balancing in bank websites they think that you are a hacker trying to hack them because you enter across 2 different connections to the same place.
