Login router os
i Have a sxt sq router os v 6.49.2
facing a security issue on my devices. Although I've restricted login access to specific IP addresses and changed the default port, someone has still managed to log in to my router. I've reset the radio, but it was accessed again. The logs have been disabled, and an API port has been configured. Could you please advise me on how to resolve this?
RouterOS version: 6.49.2
Make an export (and download it to a local computer)
Netinstall latest LTS (currently 6.49.18)
Add user with difficult password, disable admin
Login with user (created in previous step)
Configure the sxt (you can use the export file as reference, just make sure that only your config is added)
i netinstall this router and change default user and difficult password
but its happening again .
Netinstall with latest LTS?
Main and extra packages:
https://download.mikrotik.com/routeros/6.49.18/routeros-mipsbe-6.49.18.npk
https://download.mikrotik.com/routeros/6.49.18/all_packages-mipsbe-6.49.18.zip
Assuming you use Windows:
https://download.mikrotik.com/routeros/6.49.18/netinstall64-6.49.18.zip
Then you may have an infected computer and everything you type or do is being remotely recorded...
Post the full uncensored /export on forum.
Just redact (not delete, redact with ****) personal info on file.
