Hi,…
i was trying to connect my modem “which using dynamic-ip” from the internet
so i created changeip.com’s account and tried to connect to the modem configuration using it,.. and it’s worked
now i want to use that domain to login to winbox,… but the winbox shows the error
“Routeros error: Couldn’t fetch index from [ip]:80: not implemented”
so i tried to log in with the dynamic ip itself without the domain but the same error
how can i login winbox using modem dynamic-ip?
my ip and interfaces
/ip firewall export
# feb/17/2012 16:38:43 by RouterOS 3.30
# software id = SN4X-Z7VQ
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
disabled=no src-address=192.168.1.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip service> print
# NAME PORT ADDRESS CERTIFICATE
0 telnet 23 0.0.0.0/0
1 ftp 21 0.0.0.0/0
2 www 80 0.0.0.0/0
3 ssh 22 0.0.0.0/0
4 X www-ssl 443 0.0.0.0/0 none
5 X api 8728 0.0.0.0/0
6 winbox 8291 0.0.0.0/0
