Login via WINBOX not working
Hello to all, after my last configuration on a remote mikrotik router I lost access via winbox. I still have access via web interface. What can I do to have gain again access via winbox? Thank you!
Check if winbox service is enabled (IP → Services) and check the port number as well … if it’s not set to default 8291, you’ll have to set it in winbox application. Check settings in firewall (IP → Firewall → Filter rules) … verify correct port numbrr and from where access is allowed (source IP addresses or address list, ingress port/port list).
Remember what kind of configuration change did you do and how it might affect connectivity via Winbox.
Update Winbox to last version.
What’s new in v3.18:
*) fixed problem where Winbox could not login into RouterOS v6.43 router for some users
