Trying to setup a hotspot with multiple profiles here.
I need to have 4 user profiles with increasing limitations. Internal use → customers.
For internal use and regular customers I would like the MAC address to be used to automatically authenticate the user. My current test config still asks for a username/password.
Hotspot profile
/ip hotspot profile
set [ find default=yes ] login-by=mac,http-chap mac-auth-mode=
mac-as-username-and-password
add dns-name=login.bla hotspot-address=10.0.0.1 login-by=
mac,http-chap mac-auth-mode=mac-as-username-and-password name=hsprof1
For the user profiles I have:
/ip hotspot user profile
add address-pool=hotspot-pool mac-cookie-timeout=1d name=1-profile-platinum
rate-limit=512k/256k
add address-pool=hotspot-pool mac-cookie-timeout=1d name=2-profle-gold
rate-limit=512k/128k
add address-pool=hotspot-pool mac-cookie-timeout=12h name=3-profile-silver
rate-limit=384k/128k
add address-pool=hotspot-pool mac-cookie-timeout=12h name=4-profile-bronze
rate-limit=256k/128k
and then my test User:
/ip hotspot user
add limit-bytes-total=5000000 mac-address=XX:B8:37:BE:19:XX name=User
profile=1-profile-platinum server=hotspot
I’m not sure if I’m misunderstanding how MAC login works or if my config is wrong.
Normal logins work fine but I need that mac login ![]()
Thanks in advance!
