One of my clients now bought a TV-set with wireless internet-access. Of course now he want’s to connect to the hotspot. Will there be any problems with the authorization-process through the TV-set or do I have to buy some other piece of hardware to put a his own private network within the hotspot?
Why wouldn’t it? It’s just like any other device connecting to a WLAN. TV makers don’t have secret protocols for their even more secret own access points - because they don’t build and sell access points
You don’t ask yourself if your client’s new notebook or iPad can connect to a WLAN, do you?
for TV set up login via mac-cookie so user does not have to use cumbersome interface of a TV to log into the hotspot. Otherway all of his experience will be - logging into hotspot.
I’d like to learn more about the Mac Cookie. I read the wiki, but it seems like the feature may lack some key abilities.
Can you use Mac-Cookie to manually add a Mac address of a TV, Xbox, PS3, Roku, etc. into the User Profile like a binding so that the Mac always ties to the User Profile?
It would be great to be able to have the Mac-cookie get added to a User Profile dynamically whenever the User logs in any device, and then if they need help adding a new device that doesn’t have a browser (TV, Roku, etc.), they can simply provide us with the Mac and we an add it to the profile. This way Mac Cookie can always hold onto all Mac addresses tied to a User so they never have to login unless we revoke the Mac, or maybe limit them to a certain # of devices.
Can this feature be achieved with Mac Cookie?
if the device has the possibility to login, it is useful to use mac-cookie, that will be created after first login, so you do not use that interface to login again (process that usually is cumbersome). If you want to pass login altogether, you can set up login-by=mac and username=, then device with this mac address will automatically be logged in, and that is the feature you are looking for.
It would be a better feature if you can tie Mac addresses to User Profiles instead of the Mac Address login since you lose features and abilities.
When you manage a hotspot with 100’s of users by username, and each of them have 5-8 wifi devices, and 1-2 devices without a browser, it becomes very difficult to manage it all. It would be so much better if you can continue to add features to the User Profile and allow to add Mac addresses in there like IP bindings, but it ties to a profile so you can continue to rate limit or limit # of simultaneous devices and add them to certain address lists - otherwise you have to hack everything and it makes it very difficult to troubleshoot.
