Logout pop-up missing after user login.
Wireless hotspot has 10.5.50.2-10.5.50.254 for ip range and is working as it should be.The logout pop-up comes up after successful client login.
On the same Mikrotik device the ether2 is configured as hotspot with 10.5.51.2-10.5.51.254 as ip range.After client successful login the logout pop-up does not show up.
If a client is logged in on the ether2 hotspot, the only way to logout is to enter the http://10.5.51.1 .
It is in my knowledge that it has to do with the ip range.
How is it possible to have the logout pop-up on both hotspots?
Do I need to edit the Hotspot Servlet?
Thank you in advance,
Mario
